Girdled Engine To O1e
  • malncol
    • Mar 2012
    • 288
    • Country: Australia
    Ok ive got a AAN with a girdled engine which has lowered the sump by thickness of the girdle thus making the sump to bellhousing bolts a no fit
    So what have others been doing to solve this???
    Or do nothing??
    thanks
    mal
  • speeding-g60
    • Aug 2008
    • 1186
    i have NEVER run the three bolts from trans to oilpan (sump) in my drag car.
    it is >900 AWHP, has >620 ft lb or Torque, and runs >167 mph in the 1/4 mile with 2.2 seconds 0-60 mph and sees >47 psi )(~429+ kpa) Boost.
    i run my motor to 01E bellhousing with 4 bolts and the one single bolt from the starter and have NEVER had a problem with this interface.
    if it were ME, i would skip them altogether. but thats just me.
    • Laaf
      • Oct 2010
      • 275
      They are left out when running a girdle.
      • malncol
        • Mar 2012
        • 288
        thanks i wish all my problems were that easy to fix
        thanks
        mal
        • JP
          • 1858
          dont runthe bolts they are only there to reduce harmonics and prevent exh manifolds from cracking. add a swivelling support to the turbo and problem solved
          UrS6 Stroker + HTA3586 =
          • G60Rallye
            • Dec 2006
            • 1321
            Same here, I have never run those bolts. Less to take to bits when pulling a gearbox as well.
