Behr radiator leak
  • Michael S2
    • Dec 2011
    • 1378
    Behr radiator leak
    Where do the main radiators usually leak from? I've read about failures of radiators before, but is it usually the cores/bleed screw/other ?
    Mine is leaking from the top plastic where it meets the core. Core looks to be in decent condition. Recently had it out to replace coolant pipes so maybe i damaged it putting it back in. (i was careful though, so i find this an unlikely cause)
    Its only a small leak when it gets hot. Is Behr still the recommended replacement part or is it worthwhile to an all alloy upgrade?
    Photo taken when cold but you can see the coolant marks.
    1995 Audi S2 Avant
  • bluequattro
    • 2960
    I ve two s2 radiators if you need a 2nd hand one to get you back on the road
    • jade
      • Jan 2005
      • 1811
      Try and firm up the crimping and see if that works
      RS 2 580HP
      • bertman
        • Apr 2007
        • 1173
        • Current: United Kingdom
        It is possible to totally un-crimp the top and remove the plastic top.remove all the crud and clean up the sealing gasket and then apply some suitable sealant.
        That is what I did on mine and is still good 2 years later.Just be careful when loosening the crimps.Did mine up by knocking them all round with a narrow bronze drift to avoid damage
        Rob
        Ragussa green avant RS2+ spec
        Racing blue Octavia VRS mk2 estate-Remapped now to 250 bhp
        Audi coupe gt-slow as hell but loads of character-sold
        • Michael S2
          • Dec 2011
          • 1378
          Thanks. I'll have a look and see if i can tighten the crimping. I'm still using the car just now and keeping an eye on levels.
          1995 Audi S2 Avant
          • rynaqui
            • Mar 2012
            • 2752
            • Country: Malta
            Are S2 radiators really such a weak point?
            I'm on a Nissens one, 2 years so far no problems..hope I haven't jinxed it
            1996 S2 ABY Silver
            • johne
              • Apr 2007
              • 1404
              Yes, they are. The Behr original ones crack at the top as the plastic ages. I'd suggest none will see 20.
              John
              • s2driveruk
                • 12696
                yep although mine appears water tight (Behr) I'm aware its been on the car for the 13 odd years I have had the car and it feels like it is time to refresh it as the cooling system on the car is worked very hard on these, more so when you have deleted the aux rad too which I did about 10years back.
                1992 3b S2 Coupe
                • Michael S2
                  • Dec 2011
                  • 1378
                  Went with a new Behr rad.
                  Audi UK price £475
                  1995 Audi S2 Avant
                  • Nuvo
                    • Nov 2003
                    • 3825
                    Is that what you paid?
                    • Michael S2
                      • Dec 2011
                      • 1378
                      £159 delivered for exactly the same unit and it was in stock unlike Audi.
                      1995 Audi S2 Avant
                      • Nuvo
                        • Nov 2003
                        • 3825
                        You had me worried for a sec.
                        • s2driveruk
                          • 12696
                          £475 WTF is that pricing all about.
                          Where did you get the new unit from btw?
                          1992 3b S2 Coupe
                          • K Simmonds
                            • Dec 2007
                            • 7627
                            You can get them for around that money on German eBay, as well as the 10 valve version more suited to cars without an Aux Rad.
                            1990 B3 2.0 80 quattro.
                            1992 C4 2.8 Avant quattro
                            1994 MTM RS2.
                            1998 B5 TDI quattro Sport.
                            2000 B5 TQS.
                            • Michael S2
                              • Dec 2011
                              • 1378
                              Audi prices are just stupid, they do nothing to help keep classic cars on the road.
                              GSF have them, don't bother with their website, just phone them.
                              1995 Audi S2 Avant
