H-beam connecting rods ARP 2000 bolts
3/8” = 10 mm diameter
1.5” = 38 mm long
I have tried to find out haw to torqued mine ARP 2000 bolts but people have all there one way haw to install them.
So far I have torqued them 30 Nm (22 lb/ft ) no lubrication/oil and measured the clearance (0.05-0.076 mm).
My plan is to tighten them to 40 Nm loosen them and finally tighten them to 50 Nm ( 36 lb/ft) lubricated with ARP stuff.
Haw have you installed your ARP 2000 rods, oil, no oil, Nm, ????
Thanks.
1.5” = 38 mm long
Thanks.
