socketed ecu
  • cooperquattro
    • Jan 2011
    • 815
    socketed ecu
    Is the rs2 ecu socketed for chips as standard???
  • prj
    • Mar 2010
    • 6308
    Some are, some aren't.
    • cooperquattro
      • Jan 2011
      • 815
      Ok thanks,i opened the ecu and it has sockets but there's plastic covers over the chips so couldn't read them,didn't fancy stripping the ecu to remove them
      I plugged the ecu back in and read the coding...all i got was a part no.and rs2
      Basically was trying to find out if it had been chipped/mapped
      Ecu has been open before
      Is there another way to see if its been played with
        Ok thanks,i opened the ecu and it has sockets but there's plastic covers over the chips so couldn't read them,didn't fancy stripping the ecu to remove them....Is there another way to see if its been played with
        Yes, remove the plastic clips so you can see the two chips in question. The clips are just there to ensure that the chips don't work their way out of the sockets.
        Factory ECU chip clips look like these:
        • prj
          • Mar 2010
          • 6308
          Does not really mean anything. It is possible to have stock software on different chips as well.
