RS2 Intercooler
  • BosnianS2
    • Apr 2005
    • 322
    • Home: Bosnia and Herzegovina Current: Germany
    RS2 Intercooler
    Well it finaly gave up. When I bought the car, obviously previos owner did not take good care of car, cause after inspecting the car I found that IC was damaged fron front crank pully impact and that was due ti fact that fron snub mount was almost totaly destroyed.
    I pressure tested the system and 2,5 years ago was still holding 1,5 bar pressure. However after my trip last month to Sweiz, i noticed that it did not run well. Boost was there (1,4 bar) but somohow I thought that it falls off too quckly. I pressure tested the system again last week and found that IC gave up at damaged area.
    I think my best option is Wagner, would you guys agree?
  • rynaqui
    • Mar 2012
    • 2752
    • Country: Malta
    Go for the Wagner, went for that on my S2 and no complaints
    1996 S2 ABY Silver
    • John B
      • Apr 2008
      • 926
      Yup....would second that. Quality kit
      2001 996 C4 - Being renovated
      • BosnianS2
        • Apr 2005
        • 322
        Appreciate the opinions .
        When considering the price of used original RS2 IC, I think it is good way to go.
        I also found a leak on my ISV (back side where connector is) and around fuel injectors, need to change seals on them. I think I need to collect everything and to it at once.
        • orsum
          • May 2010
          • 1213
          • Home: United Kingdom Current: South Africa
          PM sent
          orsum
          • Billman
            • 4129
            Or just exchange the core on the original!
            Go Holset or Go RS4
              Getting a new core welded in will be the cheapest option
              • orsum
                • May 2010
                • 1213
                Guys do you have a contact for a core? and what size would you fit?
                I have a similar problem but the nearest core size available in SA IS 550X220X65 OR 450X220X70
                orsum
                • BosnianS2
                  • Apr 2005
                  • 322
                  Has anybody done this, and if so are there any pics?
                    Had it done to the aux rad but not an intercooler by readyrads in the UK, same principle. The above damage can also be due to worn engine / gearbox mounts as well as the snub.
                    • kinaputt
                      • Jan 2012
                      • 285
                      • Country: Norway
                      Go Wagner and stiffer engine mounts
