Help please folks…….
150 miles into a tank of petrol my ABY developed a misfire/roughness that makes it very difficult to drive. It’ll still boost and feels like you’ve lost a cylinder but I haven’t. The engine shakes badly at idle but disconnecting individual injectors doesn’t isolate any misfiring cylinder. With no load it’ll rev around 2000 rpm almost smoothly.
VagCom had:
00515 Idle position switch closed throttle F60. Intermittent short to ground
00525 Lambda sensor G36 no signal intermittent
00294 Pressure switch 1 for transmission state no signal intermittent
00517 Full throttle switch F81 no signal.
Cleared these and no faults reappeared during diagnostics other than noting the removal of injector leads.
Have replaced but made no improvement:
Both POS ignition amplifiers
NGK plugs with new
All 5 Beru coil packs, loom and boots (I’ve lots of those!)
Temperatures and oil pressure normal. Compression test gives 155 to 165psi across all cylinders. Does what you’d expect if you disconnect the ISV or MAF and returns on reconnection.
Standard ABY running Homefries
Final observation; there’s a noticeable smell of sulphur in the exhaust.
Suggestions please
John
VagCom had:
NGK plugs with new
Suggestions please
John
