I need to replace the alternator on my 1994 ABY coupe.
based on body code my ABY has either Bosch 120 Amp or Valeo 90 Amp alternator
The Bosch 120 Amp p/n 0123 505 007 appears to have a 6 ribbed pk pully wheel,
the Valeo 90 Amp p/n 436 386 has a 4 ribbed pk pully wheel.
I cant see any manufacturers markings on my duff alternator, but its fitted with a 4 ribbed pully as is the main drive/crank pulley. I might be stupid as this may indicate its the Valeo alternator i need, but just wanted to clarify before purchase.
The pk belts have common pitch so a 4 pk belt should be ok on a 6pk pully, but as the Valeo is a lower rated item im hoping a forum member has had the same replacement issue as me and will have a solution.
Brian
Brian
