Hi guys,i need some help here.Last year i bought brand new RS2 turbo to fit it to my ABY .now i was going to buy new RS2 exhaust manifold from Wagner and guess what- they not available anymore 😱the only one available is with T3 flange so will not fit KKK7200.any advise what to do now????Please help
RS2 exhaust manifold-Help
You would need to buy OEM
I did warn people in this thread http://www.s2forum.com/forum/showthread.php?t=70754 -
I have the same problem, I am looking for the same EM as you need mate... Wrote even a WANTED post but no answers yetHi guys,i need some help here.Last year i bought brand new RS2 turbo to fit it to my ABY .now i was going to buy new RS2 exhaust manifold from Wagner and guess what- they not available anymore 😱the only one available is with T3 flange so will not fit KKK7200.any advise what to do now????Please helpComment
Yep because the hole is bigger for T3 and the bolt pattern is different. covered here http://www.s2forum.com/forum/showthread.php?t=35726
What you can do is make or buy the T3 to K26 adapater. 034 used to sell one but removed it from production.
Probably worth just going tubular manifoldComment
I think I agree with Jamo about going for a tubular... because having the adapter plate will modify the other distances of the DP so the wastegate exh will not fit either and you maybe could have fittings problems connecting the DP to the rest of the exhaust.
Just can't understand why they discontinued the K26 plate on an exh manifold replica that originally has the legendary KKK turbo... comments reserved.Comment
