Help required a.s.a.p
  • s2avant95M
    • 1217
    • Home: England Current: United States
    Originally posted by Jamo
    Well guys it aint my f**kin* year already.
    I aint been on in a while as i dislocated my shoulder, and now the car is again p*ssing coolant everywhere!!
    Best bit is i can't work on it as i can't pick anything up with my right arm!
    sorry to hear that m8. i wont ask how you did it.
    Tim
    1995 S2 Avant, ruby red - ** SOLD TO ROSS **
    Golf Rallye G60 ** SOLD **
    Golf MK2 Oaky with R32 engine
    Audi A6 Avant 1.9 TDi 130
    Golf MK2 8v Race car
    • Jas11n
      • 5067
      pfft,,,,just be glad you haven't got a fractured skull,,,,then crash your car a week later
      2001 Avus Silver B5 RS4.
      1995 S2 Coupe - sold (sniff)
        Ouch!, what did i miss?
        • Jas11n
          • 5067
          This below
          click the pic for the link to the thread.
          • Graham
            • 1622
            #20
            Yeah but it wont be looking like that for long and as for the fractured skull, could have been worse, at least it never damaged anything important :mischeif: J/K
            Graham
            • Jas11n
              • 5067
              I can't get anymore brain damaged than I already am mate
              Graham
                20 mph and a write off? WTF!!!!!!!!!!!!!!!!!!!!!!!
                • Jas11n
                  • 5067
                  Yup but as you can see from the pic, the main impact area was the grille,,,,the number plate is totally untouched, thing is I had so little distance to stop, I had the brakes on that hard with the ABS going crazy, the car was on its nose and my front bumper has gone under his rear bumper (54 plate mondeo )
                  These cars are strong, but when you think about it, what protection has it got at the front?? a flimsy piece of metal and an aux radiator,,,,then it's the engine
                  It'll polish out
                  • horvathg
                    • Dec 2003
                    • 556
                    #24
                    I had a similar affair with my 2,8 Coupe quattro some years ago. Front area looking similar, cost me a fortune to re-do, while the golf 2 I hit on the rear hat itself polished with a tissue towel in about five minutes.
                    Fourrings, our S2 cars are twin brothers, same colour...and I would consider suicide if this demolish was on mine.
                    Gabor
                    96 ABY coupe full except sunroof. With Porsche big red brakes, remapped ECU, xenon lights, RS2 MAF
                    • Graham
                      • 1622
                      #25
                      Mad, my car is the twin brother of his brothers S2 coupe
                        Going back on topic guys (since i still need help!)
                        1) check coolant pipe too Turbo
                        2) Pipe behing IM near PS pump
                        Anywhere else to check?
                        As soon as i can muster up some fit and able bodies (would you believe my other mate has also dislocated his shoulder, what a pair we look like!)
                        As soon as i put it in the coolant p*sses out then the level holds out at about 1/4 full in the reserviour.
                        • martinjs
                          • 3205
                          Check the connections at the after run pump, its only plastic and can crack easily. BTDT.
                          • jameswkr
                            • 538
                            If all of the above does not find the leak (and assuming its not the headgasket) look very hard at the main and aux rads - sometimes the leak is very hard to find as it evaporates off before you can see it and will not leak except under pressure (BTDT for both hoses, rads and afterrun pump). I find it odd that your level drops and then stabilises - are you sure its not the expansion tank itself ?
                            • Jas11n
                              • 5067
                              2) Pipe behing IM near PS pump,,,
                              When you say the pipe behind the IM near the pas pump, are you meaning the one down on the block that connects the stat. I've heard of this perishing and leaking..
                              • Mikes2
                                • 1704
                                There's two hoses like this.
                                One attaches to the stat housing. the other is below the PAS pump. Both are common fail items. They're only about 4 inches long and access is best with the radiator removed and the PAS pump lifted out the way.
                                Good picture here of the short hose to the stat housing:
                                Last picture at bottom of page. Part number is listed at top.
                                Mike
                                http://www.s2-audi.co.uk
