stock dump valve
  • tomwood_uk
    • Feb 2009
    • 336
    stock dump valve
    Quick question, will the stock aby recirc dump valve be ok for 1.4/ 1.6 bar boost. Going in for mapping on the 13th just wanted to check.
  • andy10v
    • 5996
    Should be fine as long as it is not damaged.
    If you are replacing then people often us a 710N from a 1.8t as an oem upgrade as it has a stronger diaphragm.
    Sold ABY-stock
    • Laaf
      • Oct 2010
      • 275
      I'm having a 710N valve on 2.1 bar boost. Works a treat.
      • tomwood_uk
        • Feb 2009
        • 336
        Thanks guys
          BPV info as it relates to UrS Motronics
          Originally posted by tomwood_uk
          Quick question, will the stock aby recirc dump valve be ok for 1.4/ 1.6 bar boost. Going in for mapping on the 13th just wanted to check. Cheers
          Just some more By-pass valve (BPV) info to confirm the goodness of the 710N.
