My car has an MTM ecu and the "special hybrid MTM turbo", whatever that is.
Does anyone know the difference between this turbo and the standard one? I have just fitted a boost gauge which max's out at 1.4 bar which, iirc, is pretty much the norm after standard chipping.
If the boost is the same, what's the point in changing the turbo when something like a homefry doesn't require it?
