Need help with injectors!!!
  • Newmember
    • Feb 2012
    • 82
    Hi everyone!!
    I've these injectors : http://www.fiveomotorsport.com/825cc...deka-iv-110324
    Everything was fine before I have noticed that they are EV1!!!
    Will they work on my engine AAN? Engine is totaly rebuild! New pistons, new rods and so on!
    Or the easiest way to sell them and buy the rigth one?
    Thanks for help!
  • BosnianS2
    • Apr 2005
    • 322
    • Home: Bosnia and Herzegovina Current: Germany
    Are you wanting to increase your power or stay stock?
    • Newmember
      • Feb 2012
      • 82
      Yes,up to 650-700hp. Why I am asking,that everybody are using EV14 and I have EV1!! Will they work properly or no?
      • Biturbo
        • Aug 2011
        • 591
        • Home: Lithuania Current: United Kingdom
        I'm using this deka injectors,and on petrol 657hp is max for them with 2 pumps and an8 fuel lines 4.5bar pressure.With one pump in tank and stock fuel lines it was around 550hp.If you run e85 you will need much bigger.
        • Newmember
          • Feb 2012
          • 82
          Prj told that EV1 are not the best injectors. But I want to know why and has enybody used them?
          • Newmember
            • Feb 2012
            • 82
            Biturbo- you have the same and EV1? And they work as good as EV14?
            • Biturbo
              • Aug 2011
              • 591
              Mine is EV1 80lb/830cc high-impedance.This is direct fit no need any adapters or any thing.Run on this second season no problem.I had for about 2 month lukas 1260cc,but they start stuck,so I'm back to siemens deka.For next season I will need bigger so I go for bosch or dynamic injectors 2200cc
              • Newmember
                • Feb 2012
                • 82
                Good,good. I will drive with metanol injection,so it help to get my 650-700hp.
                • Biturbo
                  • Aug 2011
                  • 591
                  That turbo?I'm using methanol injection with one injector 950cc also.
                  • Newmember
                    • Feb 2012
                    • 82
                    What turba are you using?
                    • Biturbo
                      • Aug 2011
                      • 591
                      Holset hx40 hybrid that with 64mm billet compresor wheel and 16 cube hot side.I have high lift cams and solid lifters to fit in,so power will go up
                      • Newmember
                        • Feb 2012
                        • 82
                        Nice! I have HX40 super and high lift cams (11mm) if compare with stock cams )) Thinking of solid lifters too... but before I have to put together my engine. Can't wait to start and hear it))
