which studs with Wagner exhaust manifold
  • LeoLeandro
    • May 2008
    • 26
    • Country: Switzerland
    Hello every one.
    i'm experiencing an issue mounting my Wagner exhaust manifold.
    the Studs M8x27mm (rs2 short version) are to big to be able to install the manifold.
    When you try to fit the manifold, it touch the end of the studs before he is good fited.
    can some one please tell me the good studs size?
    Thank you in advance
  • rynaqui
    • Mar 2012
    • 2752
    • Country: Malta
    I am using RS2 studs on my exhaust manifold and had no such issue, are you sure they are genuine RS2 studs?
    1996 S2 ABY Silver
    • quattro-nick
      • Sep 2012
      • 1746
      • Country: Belgium
      i had the same issue with my exhaust manifold and i just shortened the studs
      TWINCHARGED power,zero lag
      AEM W/M injection
      • twenty valve
        • Oct 2010
        • 630
        And me
        • LeoLeandro
          • May 2008
          • 26
          Hello.
          Yes i'm sure. i order the complete exhaust kit from 034 motorsport and the studs of this kit are the rs2 short studs (m8x27). The wagner evo exhaust manifold are to big and the studs tuch the manifold.
          Ok so if i understand well, every one cut the studs
          Thank you all for the fast reply.
            034 studs are replicas and are not OEM, you'll need to shorten them. I had no issues using oem rs2 for the rs2 evo or 034 on the sq replicas however.
            • popdemonic
              • Dec 2007
              • 1304
              • Country: Thailand
              Recently i have fitted RS2 Wagner 'EM. I need to grind off(shorten) upper studs.IIRC 4 studs will be shorten otherwises you'll expriencing hard time to put the 'EM on.
              It ain't big deal. you just put the 'EM on and mark which sutds is your problem.pull the 'EM off and grind them one by one.you couldn't be using the genuine RS2 'EM
              as your guideline.the short studs being mounted on different postion.
              one of a few I5 from Asia.
              • popdemonic
                • Dec 2007
                • 1304
                • Country: Thailand
                I couldn't find the best photo but if you tried to look it closer the upper row studs excluded the outer left and right needed to be shorten.i guess 4-5studs.HTH.
                • GazzaG60
                  • 4133
                  mine just bolts up with the tubular wagner
                  • piotr
                    • Jul 2012
                    • 1470
                    Is anyone know the torque values for them studs and nuts ?
                    • martinjs
                      • 3205
                      25nm
                      • piotr
                        • Jul 2012
                        • 1470
                        25nm to studs in head or nuts?
                        • martinjs
                          • 3205
                          Studs finger tight, 25 on the nuts, thats how I've always done it.
                          • RichLV
                            • Mar 2015
                            • 872
                            • Country: Latvia
                            I just cut the standard manifold studs and that's it. Threw some copper nuts on them and all good.
                            • piotr
                              • Jul 2012
                              • 1470
                              25nm for nuts sounds good but I would be slightly concerned to do them just finger tight I would expect they should be somewhere between 20-25 as well ,anyway,thanks for info chaps
