part numbers oil screw Urs4 and rs2?
  • MattP
    • Apr 2012
    • 129
    • Home: Luxembourg Current: Belgium
    Hi
    Anyone knows the part number from the oil change screws?
    My local audi dealer tried 3 times to order but none of those screws looked like and oil change screw
    Part number AAN s4
    ADU RS2
    Ow and if i am correct there is no copper seal around them? Is that really needed?
    Can i use any iron/zink/copper... seal?
    AAN and ADU (and ABY) all the same = Items 15 and 16
    • MattP
      • Apr 2012
      • 129
      Last time i changed the oil on the s4 it was a normal screw like the one on the right (polo 6n).
      And it looks pretty big...but can be don't remember it that good?
      Now need to find the gasket rings...for a fair price.
      http://www.ebay.es/itm/N0438541-Drai...-/281338913429
        The one on the right looks correct for the AAN. The one on the left looks like the one on my 1994 S4 ABH V8 oil sump.
        • MattP
          • Apr 2012
          • 129
          The thing is the one on the left has partnumber 059 103 193 but it looks too big indeed but if you google that partnumber you see the same big bolt.
          Any idea what part number a normal screw is? (that one on the left is from my vw polo)
          • irishs2
            • Apr 2009
            • 2455
            Just thought I would post this,
            ABY non air con
            Eric
            95 S2 Avant under rebuild.
            • MattP
              • Apr 2012
              • 129
              Well i guess it should work out then.
              I guess there is some cheaper screw in my oil drain hole.
