oil leak from front seal
  • malncol
    • Mar 2012
    • 288
    • Country: Australia
    Ive just had the AAN running in the S1E2 project of mine and the front seal is leaking but not at idle,Only seems to do it with a few revs on board??
    its got a high volume oil pump from 034 on it and iam hoping its not a pump problem
    Its making good oil pressure. I was thinking maybe breathers ?? It has the big breather in the block going through a 1/2 inch pipe to a catch can and seems to be working well
    Maybe oil pump is leaking a bit of pressure against the back of the seal ??
    any thoughts
    thanks
    mal
  • Monkeymagic
    • Mar 2012
    • 3419
    Just sounds like the seal is simply goosed to me
      Although as with most 034 stuff, the pump probably doesn't fit or has something wrong with it too
      • Monkeymagic
        • Mar 2012
        • 3419
        Ha ha such mis trust. What's wrong with the oe pump they seem pretty bomb proof On the 5 cylinders.
        You would hope with something as crucial as an oil pump they would design it right or risk lots of expensive warranty claims
        • malncol
          • Mar 2012
          • 288
          yes ive had issues with some 034 stuff, latest one is the quick rack that i bought is not assembled properly , fired the car up and it when to full left lock all on its own, nearly broke my wrist
          put old rack in no problem at all
          hope your right about seal cause if its the pump then my rally is over before it starts.
          dyno day is wednesday ,ill get a new seal in before then and hope for the best
          thanks
          mal
          • quattro-nick
            • Sep 2012
            • 1746
            • Country: Belgium
            if it's a breather problem than likely the rear seal leaks also
            maybe you can disconnect the big hose(1/2 pipe) on the catch can and let it hang in open air and see if this solved your problem
            you can also measure the max oil pressure
            my origional new AAN oilpump gives almost 8 bar on cold temp without problems or leaks
            TWINCHARGED power,zero lag
            AEM W/M injection
            • malncol
              • Mar 2012
              • 288
              yes we did check the breathers and all seemed well, i think iam stressing to much hopefully its just a seal
              does anyone know the dimensions of the front seal on a AAN , are they the same on all the 5 clys??
              thanks
              mal
              • Monkeymagic
                • Mar 2012
                • 3419
                Why do you need 8 bar? Am I missing something surely this is why pumps have a pressure relief valve? I ask this as a genine ququestion.
                on my 2 golfs we used to fit the higher volume pump from a mk3 to accommodate the piston oil squirted things but it kept the pressure the same
                • DJones
                  • Jun 2005
                  • 2020
                  You will probably find it's a rubbish front seal, new pumps seem to come with some cheap plastic lipped seal. I always take them out and fit a rubber lipped seal.
                  Oil pressure won't cause this problem, crankcase pressure will but you won't get much of that without boost and from what you describe it's not seen boost yet.
                  The big breather going down to a half inch pipe won't cope with boost. It won't shift enough volume and you will get crankcase pressure causing leaks.
                  Hope it helps
                  Darren.
                    thanks
                    mal
                    Sounds like what happens if you accidentally fitted the RS2 banjo with a check valve in the fluid return line from the rack - BTDT
                    • malncol
                      • Mar 2012
                      • 288
                      i think i fitted new bango bolts ,so dont think they have valves ? I used the same banjos with the spare rack and it was all good but i will check
                      • malncol
                        • Mar 2012
                        • 288
                        Hope it helps
                        Darren.
                        so what size breather would you use ? and yes it hasnt seen any boost yet
                        • DJones
                          • Jun 2005
                          • 2020
                          Match the size of the exit holes from the engine all the way to atmosphere, if it passes through a separator make sure the vents from that also match the exit holes from the engine, any smaller and it will create a restriction. You will be amazed how much pressure you get in the crankcase when on boost.
                          I have seen them blow the dipstick out like a bullet.
                          Darren.
                          • quattro-nick
                            • Sep 2012
                            • 1746
                            • Country: Belgium
                            @ Monkeymagic: i dont mean that he needs 8 bar,mine just gives almost 8 bar a minute or so with cold(rebuild) engine,it's a new pump and have the origional pressure relief valve with a 3mm washer.
                            a s2 oilpressure gauge goes maximum to 5 bar so you dont know what actually the max pressure is from the car
                            AEM W/M injection
                              yes we did check the breathers and all seemed well, i think iam stressing to much hopefully its just a seal does anyone know the dimensions of the front seal on a AAN , are they the same on all the 5 clys?? thanks
                              mal
                              Mal: I think I answered all your questions (and more) in this new post:
