Hi guys,
So gypsies stole my piston set for the AAN and i was thinking if stock 7A pistons could be used with boring the engine to 82.5. Are the made from the same material? Should I drill the hole in the 7A piston to lower the compression or use thicker gasket? Can they hold RS2 specked setup?
