Engine noise?
  • V6quattro
    • Sep 2008
    • 949
    Originally posted by s0_big
    The same typ of noise that you have. I Also use harder enginemounts and 034 "track density" tranny mounts. Also i have JE-pistons. Otherwise my engine is doing fine, god oil pressure and smoth runing, exept the noise at low revs. I also dismantled my engine because i was worried but everything was fine. The only thing i saw was little "wear" on the piston skirt on the pistons. Do you guys have pictures on you pistons when they had run for some time?
    These are the engine mounts i have:
    I have photo's from my pistons and the skirt-wear on them. There was also a little wear on the cylinder walls (on the photo the cylinder wear looks much worse than it actually is!)
    • V6quattro
      • Sep 2008
      • 949
      Originally posted by Laaf
      I have the same noise in my 4k quattro with 2.2t. I run 034 Motorsport spec mounts on engine and tranny so it is quite harsh. I have the dash pulled now as I am going through the electrics in the car and I've also removed the insulation as it was torn in alot of places anyway and I won't mind the noise. I'll just have to wait and see how I feel about the noise later on.
      I made the clip while having problems with a bad tappet, http://youtu.be/wTRIAPPRIy4?list=UUc...dnCXra2Wp8-aag
      I don't have a problem with the noise as long as i know my engine is not about to explode soon
      Originally posted by S2SE
      Hi!
      Yes I have JE pistons and they have a little wear on the skirts but nothing I reacted to really. Ive driven maybe 3000km with this now.
      Pleas keep us updated if you experience any problem later on!
      • diesel des
        • 3896
        What piston to bore clearance are your guys running. Sounds like ot could be slap. Have you tried listing with a stethoscope on the block. Try down low near the crank and higher up near the head to tell if its bearings or slap.
        Sent from my GT-N7105 using Tapatalk
        • S2SE
          • Mar 2012
          • 91
          To be honest, I dont know my piston clearance but the block should be bored to fit the pistons. Havent tried to listen with a stethoscope either.
          • diesel des
            • 3896
            #20
            Some of these forged piston manufacturers seem to specify a lot of clearance , I suppose they don't want something to seize up. I'm sure you could get away with something tighter...
            • V6quattro
              • Sep 2008
              • 949
              If it was piston slap it would by a lot louder on cold engine than when hot right? My engine sounds good on cold start.
              • diesel des
                • 3896
                #22
                In theory yea it should be louder cold, but maybe the thick oil helps. I don't know
                • V6quattro
                  • Sep 2008
                  • 949
                  Any news on this? Last month i did around 20 dyno passes and made 709hp 777nm and 8 1/4mile passes. Also around 350km street driving. Slapping/knocking sound did not really changed.
                  • s0_big
                    • Dec 2009
                    • 685
                    Good
                    My engine has over 1000km hard driving on it now. The sound is still there. Seems like its nothing to worrie about. The sound is the same hot/cold engine.
