I connected the battery today after an extensive engine re-build and found that the fuel pump is always running, even with no key in the car!
I have a second fuel pump relay under the rear seat which is switched using the green/yellow wire that originally drove the pump and this seems to be live all the time. I've checked the original J17 pump relay and the G28 engine speed sensor, both seem to be working normally, but the pump still runs, even with both of these unplugged.
I know the ECU looks for 13rpm from the G28 before switching on the pump, so what could be broken on mine that making the pump live all the time??
