how to remove the seized exhaust housing on Garrett GT?
  • popdemonic
    • Dec 2007
    • 1304
    • Country: Thailand
    today i started to remove the Garrett GT2871 for a rebuild and Billet compressor wheel.
    it's a bit tough since the bolts and nuts on the exhaust were all seized and tough to get
    them out one by one.I sprayed and soaked them with WD-40 seems little helps.
    once everything taken apart except the exhaust housing was seized on the CHRA.
    I have tried to hammer,WD-40,heat gun(I think it's useless) etc.all didn't work out bit.Damn it.this's PITA.
    anyone has any ideas to remove the exhaust housing.i couldn't hook up the bearing cartridge and remove the turbine shaft since there's the backing plate left behind the exhaust housing.i will do the full write-up on how to assemble/disassemble the Garrett
    GT ball bearing turbo since this's not available through the internet and someone is selling the DVD for 20quids IIRC.i found there're a couple tips working on the Garrett turbo and hope it helps for someone wants to do it besides paying big money to the shop.
    one of a few I5 from Asia.
  • andy10v
    • 5996
    Heat. (oxy acetylene or propane, not a heat gun)
    Warm the hotside housing evenly and it will expand, also helps break any corrosion bond.
    Sold ABY-stock
    • popdemonic
      • Dec 2007
      • 1304
      • Country: Thailand
      Thanks Andy.it's all out now with lotta heat on the housing.
      • EspenW
        • Apr 2007
        • 1534
        • Country: Norway
        Yep, heat on the outside and if that is not enough, use freeze spray on the bolts, for maximum thermal expansion/contraction effect.
        1994 80E Avant
        1986 2L Golf 2 on Alcohol
