Replacement injectors
  • Rikki Kitto
    • Feb 2010
    • 6276
    What is a good replacement for standard S2 injectors, maybe small upgrade, never going to go big power in the future 300-350bhp max.
    Rather than get old ones refurbed or cleaned there must be some good alternatives out there, any ideas welcome
  • s2driveruk
    • 12696
    refurbing is not a bad idea in all honesty, its about £60 and they are flow tested, ultrasonically cleaned, tested again and then new caps and seals. I had mine done a while ago and the service was top notch. There was quite a difference across the 5 and if you buy 2nd hand ones or new old stock, you would be advised to get them done anyway to be sure you know their health.
    1992 3b S2 Coupe
    • quattromobbin
      • Mar 2014
      • 21
      your across the pond but 034 motorsports has a badass set of rs2 replica injectors that are affordable. check em out! if you order em call and ask for Jeremy and let him know that Brett from Colorado sent u and he will hook u up! http://store.034motorsport.com/rs2-r...set-20953.html
        No point just changing injectors as you will need to change your software too. Just get them reconditioned. My 2c.
        • quattromobbin
          • Mar 2014
          • 21
          however i think they are for use with rs2 tune??
          • quattromobbin
            • Mar 2014
            • 21
            lol i just thought of that man hahaha yall are always one step ahead of me!!
            • Rikki Kitto
              • Feb 2010
              • 6276
              I've got lots of spare sets so could send a set off for recon and clean,who's best guys, PS got the loom mate cheers fitting it today or tomorrow
              • mike74
                • Apr 2014
                • 615
                I've used these guys in the past. They cleaned n tested the (4-off) injectors for my GTIR and cleaned the fuel rail for £67 within a few days.
                Good service and pretty good price too I thought
                sales@injectortune.co.uk
                • Rikki Kitto
                  • Feb 2010
                  • 6276
                  Where did you get yours done
                  • s2driveruk
                    • 12696
                    www.injectorcleaning.co.uk and did the fast turn-around option
                    1992 3b S2 Coupe
                      I used these guys recently and they did an excellent job and quick turnaround.
                      • Bowie69
                        • Nov 2013
                        • 2675
                        I used them and one went back a few months later as complete failure, failed open... they did however send a replacement out ASAP once I queried having to wait until they had inspected the old unit!
                        12,000 mile/12month warranty I believe.
                        • Rikki Kitto
                          • Feb 2010
                          • 6276
                          Cheers guys loads of help as always looks like I'll be posting a spare set off to these guys soon then
