MHLE motorsport possible group buy
  • ralleyquattro
    • Oct 2007
    • 536
    • Home: Poland Current: Canada
    There has been a bit of a confusion regarding sport pistons I was going to copy for my Sport project, I assumed that KW used 144mm rod, where in fact it does not.
    So... looks like I am getting some pistons made and I am given 2 options:
    1. Pay $1400+ for a 1 off set of 5 pieces
    2. Pay $800 for a set of 5 pieces if I can meet the MOQ
    Considering JE’s go for roughly $1200 to $1500 depending on the options I am going to go the Mahle Motorsport route.
    Here are the stipulations:
    • MOQ of 40 pieces – 8 sets of 5 cylinder pistons.
    • Mahle 142 Alloy forging will be used ( a blend between 2618 & 4032 alloy)
    • Lead time 4-6 weeks (Could be longer , could be shorter as it depends on when they will be cutting another group from that forging).
    • Mahle proprietary Grafal coating applied as standard (no need to farm out for coated skirts and crowns like the JE’s)
    • Fixed CC for Dish volume
    • Fixed cut out for intake valve diameter – I would probably go with +2mm oversized on the cut outs for those running Ferrea/Supertech larger diameter valves
    • Fixed Compression Height – so for those who want to use the 2.5L block will be forced to use a 160mm connecting rod.
    • Fixed wrist pin diameter
    The only variable will be the bore diameter.
    These will be the specs for my set:
    • Bore = 79.5mm
    • Stroke = 86.4mm
    • Block = 7A/AAN/ADU/3B @ 220mm Deck height
    • Connecting Rod length = 144mm
    • Compression Height = 220 – [(86.4/2) + 144] = 32.8mm
    • Piston Dish CC = 12cc
    • Wrist pin = 20mm
    An Elring AAN 20V Turbo head gasket has a max bore of 82.2mm and a thickness when fully compressed of 1.6mm = 8.49cc
    A Stock 7A cylinder head with flat Ferrea/Supertech Standard Size valves has a volume of 44cc in the valve pocket area.
    Vc = 4cc + 44cc + 8.49cc = 56.49
    79.5mm bore x 86.4mm stroke = 2144.4cc : Vh = 2144.4 / 5 = 428.88 cc / cylinder
    81.0mm bore x 86.4mm stroke = 2226.1cc : Vh = 445.20 cc / cylinder
    81.5mm bore x 86.4mm stroke = 2253.7cc : Vh = 450.74 cc / cylinder
    82.5mm bore x 86.4mm stroke = 2309.3cc : Vh = 461.86 cc / cylinder
    83.0mm bore x 86.4mm stroke = 2337.4cc : Vh = 467.44 cc / cylinder
    Based on my math a 79.5mm bore piston (for me) will yield the following:
    E (compression ratio) = (Vh + Vc) / Vc
    = 428.88 + 56.49 / 56.49
    = 8.6:1 CR
    For sample if I went to an 83mm bore the CR would be:
    = 467.44 + 56.49 / 56.49
    = 9.27:1 CR
    So the range of CR will be from 8.6:1 to 9.3:1 depending on the bore size chosen.
    Now these are the possible combinations for the order:
    (1) 79.5mm bore x 86.4mm stroke – Martin Pajak
    (4) 81mm bore x 86.4mm stroke – for the AAN users with a good bore
    (2) 82.5mm bore x 86.4mm stroke – for anyone that wants to overbore the block
    (1) 83mm bore x 86.4mm stroke – for 2337cc
    The remaining 7 sets can be any number of combinations for the bore size. Without meeting the MOQ this will be a custom order.
    If you are interested, let me know
    Martin Pajak
    www.quattro.ca
    B2: 82 Urq into Sport quattro, 82 4000 2-door, 83 80q 2 Door, 83 Ur-q CDN, 85 Ur-q Euro with 3B, 86 4kq, 59,000km
    B3/B4: 91 CQ, 93 90q 2.5TDI, 94 80q avant 2.5tdi, 94 S2 Avant
  • my2000apb
    • Jul 2010
    • 637
    wanna sell me that singleoriginal piston?
    BEAST '90 CQ 24v VRT / O1E / v8 rear, HOLSET SUPER 40 http://www.theprojectpad.com/viewtop...1&t=193#p37887
    DD '86 4kq BLAZE, swapping aba/16vT and O1E http://www.theprojectpad.com/viewtop...1&t=201#p38264
