Ok before anyone says it YES I know a conversion is going to be better in the long run etc etc..... guys I know this but funds don't permit right now so will have to wait for a bit
Over the last few weeks noticed a misfire under load, idled fine so just thought it would be a coilpack issue rather than POS.
Went to ADI and was given some coilpacks to try and once installed it misfired even on idle so decided to put my old ones back in, put them in and now wouldnt idle on all 5 as it did before so I assumed it was down to the wiring that I would of disturbed.
Re-wired 3 of the coil packs as they were very brittle,put them back in and still rough, only idling on cylinders 1,2 and 3 (pulled the injector plugs off to narrow down),whilst it was running I pulled the plug off the N/S pos and it made no difference, so this confirmed it was definitely 4 and 5 not firing.
Received some POS units today to try and still the same.whilst the engine was running I also pulled the multiplug on the bracket where the other end of the POS unit connects and strangely this made the engine cut out.
I am guessing there is a wiring fault somewhere, the coils are effectively -/+ ?
I have narrowed it down to the 2 black wires that come off the back of 4 and 5 and go to the N/S Pos, these are the negative wires to coils.
