I have recently bought a S6 Auto and the car doesn't go like it should, my 80 TDI seems faster
The car only shows 1.4-5 bar on the computer so 0.4-5 bar
I was luck enough to get Error/Alex to put VAG.COM on it at ADI and only one fault came up (idle switch, which he cleared and didn't come back)
There was a figure that wasn't moving on the laptop which Alex thought was a boost leak on a small air pipe / map sensor in ECU? I carried out a mitivac test and it held pressure ok, I did tighten all the small pipes that connect to the inlet manifold.
Next thought was ECU fault, ive swapped it with one I know is ok and no difference
Can someone please confirm what an S6 Auto should boost to? would there possibly be a fault with the Auto ECU causing it not to boost? or can someone give me some advise on what to check next.
Car has only done 116k with good history, it doesn't smoke/use oil or water, its got to be a sensor surely?
The car only shows 1.4-5 bar on the computer so 0.4-5 bar I was luck enough to get Error/Alex to put VAG.COM on it at ADI and only one fault came up (idle switch, which he cleared and didn't come back)
only went on a short test drive and the car was still cold so I didn't give it the full beans but I did see the dash show 1.7
changed the N75 last night, took the car to the farm tonight for someone look at the air con, found a loose pipe so hopefully tighten that and i'll have working climate
car was running and when i put the connector on i heard it click. i only had half a mile to home but when i gave it some, it boosted to 1.7 (might go higher but i didn't have time to take it on a longer drive)
My own fault for using a duff windage tray.
This is a low boost thread not a rear suspension thread. Bump your other thread again and kill the post above.
