Coolant Capacity For Aby
  • bilko0795
    • Feb 2011
    • 1883
    As above can someone tell me the capacity iv searched on here and found 7ltrs for the ABY and 9ltrs for the AAN thought they were the same engine ?
  • Rusty
    • 18953
    Depends if you drain the block. 7 litres for a complete flush sounds about right.
      7 litres sounds about right. I normally put 3 x 1Ltr of G12 in, then top up with water
      • Rusty
        • 18953
        If you only drain the rad, it's closer to 4.
        • bilko0795
          • Feb 2011
          • 1883
          Thanks guys just bought 4.5ltrs of G13 so 2 bottles and just fill with wasser and before you ask they come in 1.5ltr bottles
