The Dummy's Guide to Direct Ignition & Coil-Packs etc
This is a sticky topic.
    I put some midnight oil into this document to get things started... You will see I have more to do, but I would happy to get some feedback from folks on the usefulness of this kind of document.
    It's a little more wordy than I had originally intended but that is nature of the beast. I hope it is useful info for people - even if they cannot understand all of it.
    Next part is to capture some real world signals, verify the theory and confirm the location of the dwell table in the ECU... all subject to getting some quality time in the garage !
    JUMP TO http://www.s2forum.com/forum/showthr...#post819050FOR LATEST VERSION
    Fantastic work Paul. On a very quick read through, I only caught one error: The UrS4 V8s do NOT have direct coil ignition. I have a 94 S4 V8 avant with the ABH V8 and it has two distributors and two coils and 8 distributor to plug wires. I don't think there was coil on plug V8s until the A8 (and the S6 plus ABK).
      Actually - that sounds right - it was 2nd generation V8. Noted
        • 4754
        I had a look despite being pretty much useless at Auto Electrics and what i saw looks very professional and superb content! Thanks
          30 views and 2 comments. Chew this over folks and report back with ideas for improvement and / or anything you would like to see added... I have limited time this week to crunch it some more.
          • VagOrBust
            • Feb 2010
            • 107
            • Home: Netherlands
            Hello Paul,
            I gave the document a quick glance and it looks spot on.
            When I'm off later today I'll give a thorough read.
            I was going to say that I'm missing Fault diagnoses and the modern wire loom and 2.0 TFSI coilpack upgrade, but I can see in the table of contents that your already planning to add those.
            Please keep up the good work!
            5 cilinder addict:
            1995 UrS6, 2.2 turbo, daily driver, EFI coilkit, custom exhaust.
            1993 S2, 2.2 turbo, ABY, long term project.
            2006 Ford Fiesta 1.4 TDCI. Because reasons.
            • quattro-nick
              • Sep 2012
              • 1746
              • Country: Belgium
              nice info paul
              but like VagOrBust say,maybe it's handy if you give some extra information about how to convert the origional coils to tfsi coils with a wirediagram,partnumbers and dwelltime
              TWINCHARGED power,zero lag
              AEM W/M injection
                Just had a quick glance and looks good, will have a proper read later
                  There is a lot of coil info in these posts of mine:
                  General Coil info:
                  POS diagnostics:
                  And this ("One missing and hesitation diagnostic"):
                    Sure - will try to reflect any highlights from those threads.
                    • EspenW
                      • Apr 2007
                      • 1534
                      • Country: Norway
                      Minor correction: ABK is the 2.0E 4 banger used for example in my 80 Avant. The S6 Plus had the AHK.
                      1994 80E Avant
                      1986 2L Golf 2 on Alcohol
                        Thanks. I knew that (and forgot to check my notes).
                        • BosnianS2
                          • Apr 2005
                          • 322
                          • Home: Bosnia and Herzegovina Current: Germany
                          I just read the whole thing and must say great work. I am always appreciating someone taking his time to create something that at the end helps hundreds of people
                          Great work
                            These diagrams of mine could help:
                              Rev02 attached with Appendix C added and a few other minor edits.
                              Jump to http://www.s2forum.com/forum/showthr...050#post819050 for latest version.
