aan engine. more revs??
  • elaw
    • Jun 2012
    • 62
    Oops... not down but I somehow managed to put a quotation mark at the beginning of the URL!
    Should be fixed now.
    Be alert! America needs more lerts.
    Eric Law
    '90 80Q with AAN and Megasquirt
    '97 Saab 9000 Aero: mostly stock but ECU tweaks to add fastness
    '86 4KTQ: R.I.P.
    • Laaf
      • Oct 2010
      • 275
      I had lightweight hydros installed for about 30 min of engine running time before swapping back to OEM. They started making an awful noise and when taking them out 2 were soft, not almost stiff like they should. They are still lying on the shelf in the garage.
      • Biturbo
        • Aug 2011
        • 591
        • Home: Lithuania Current: United Kingdom
        Originally posted by Rusty
        Head £1500+ Cat Cams + adjustable gears, £1000+, engine £5000+, dry sump £2500+... ish.
        Schtick, DBillas, Cat Cams, Dahlback & various Swedish mentalists for cams.
        This all you need if you rev till 10000 rpm Can't wait to see how is feels.On stock oil pump I rev till 7900rpm no problem at all
        • Thuppu
          • 4115
          Originally posted by Quattronaut
          IMHO stock hydros are usable to 7500 rpm, some aftermarket lighter ones till 7800 with better springs- but in this rpm range their use is risky, and they will be worn out fast. And we are not speaking about a car that is used on street and driven normally all the time, and that is in real high revs from time to time. We are talking about a track and race car, that will be driven in high rev ranges most of the time. I for myself do not think that hydros are usable that way real safe.
          I meant the 540hp that way, that peak powers up to around 540 hp are reachable with stock valvetrain, hydraulical tappets, no need of solids. Only when you go higher, you will need mechanical valvetrain. And I am not only speaking about damage, but also about sense- turbos, that are able to do 600hp, are that big, that boost will be at 5000rpm- when the rev limitter cuts it off at 7200, you are running into rev limitter at full boost, that can cause several damage; and the usable power range is senseless, only 2000 rpm range.
          You have a very strange way of thinking about this. I would never use lightweight tappets in a high revving engine, they hardly hold in a stock engine, so 8krpm with high lift cams and stiff valvespings and they collapse for sure.
          • terrybullwon
            • Mar 2006
            • 8782
            How many people have collapsed lifters?
            Chef
            • Thuppu
              • 4115
              Ask Repo.
              • repo
                • Dec 2004
                • 893
                Yea, btdt. I had a set, a friend tried two sets in his engine, before he swapped in to "heavy ones".
                We had the faces to crack in high rev race engine. A friend had them going oval. I haven't used the lightweight ones since 2008 or so.
                Lightweights are fine for stock engine and stock springs, but not for high revs or stiff springs.
                • varia
                  • 821
                  • Current: United States
                  #23
                  an interesting read on the subject
                  • Quattronaut
                    • May 2013
                    • 273
                    Ok, note for myself: Never write posts in the middle of the night: The lighter one´s ARE CLAIMED to be usable up to 7800rpm. My opinion is, that this is risky, and they in fact should not be used like that. Sorry for that one
                    I know that the light ones are something for making money with, nothing else...the 8000rpm with the stock ones is something that I am a bit doubtfull on, I would have said "no way", but in if you say it works...hm. I dunno :-)
                    • Thuppu
                      • 4115
                      My point was just that the revvs is the one what stress the tappets, not the power itself. For example the 5cyl engine can make 700hp at 7500rpm's which is perfectly ok for hydro tappets. You just was thinking a lot more complicated at this. There is nothing wrong with that, and you are right that with a big turbo the powerband is quite short if using stock rpm limit.
