Evening, sorry for not posting much before I have been busy with my s2 and wanted to have her back on the road before I done a full write up which I will do at a later date, anyway I have had the engine and gearbox out had the head off the engine as a couple of the water manifold studs had sheared, once these were sorted I taken the sump off the engine cleaned all the block painted it, had all the parts sump, inlet manifold ect all powder coated and refitted them all with new gaskets and put a new cambelt, idler and water pump on off Pete at Quattro parts who I have spent nearly 2k with! :/ I've now got the engine in, but have left the power steering pump off until it's all running okay I've got all coolants ect in but the engine is only running on two cylinders?? It's hard starting and then only fires on two and runs very Rough as you can imagine.. Can anyone help me?? The cambelt timing is spot on with the cam and the distributer timing appears to be ok, the ht leads are on the distributer in the correct firing order 1,2,4,5,3. The injectors are all working as I've turned it over with them out the manifold and they are atomising as they should be and all the plugs are sparking as I have taken them out and can see a nice spark on all of them.. There's one wire I've attached a picture off which I don't know where it goes near the oil pressure sender? It's 3 pin with 2 red wires and one brown/green... Any help would be appreciated as I'm about ready to bounce it!
