Correct AFR
  • HMS-S6
    • Jan 2010
    • 1164
    Correct AFR
    Hi all,
    I've finally dug my S6 out and fitted the wideband I bought for it over two years ago!
    What figure would you typically expect on wot from 3,000 to 5,000 rpm?
  • Jaswan
    • Apr 2011
    • 760
    out of curiosity what brand have you/did you go for?
    thanks
      Originally posted by HMS-S6
      Hi all, I've finally dug my S6 out and fitted the wideband I bought for it over two years ago! What figure would you typically expect on wot from 3,000 to 5,000 rpm?
      Hey there!! Long time no post? Hope things are good.
      As for your question, my off the top answer was going to be an AFR of around 11. Here are some UrS AAN dyno results that back that up:
      • HMS-S6
        • Jan 2010
        • 1164
        Yeh, mines dipping to 10.8 or so on WOT so obviously not a fuel trim issue it would seem. Still edging for a hiding boost leak maybe!?
        • twoqu
          • Sep 2003
          • 3103
          • Rusty
            • 18953
            High 11s low 12s
            • ineora
              • Sep 2009
              • 109
              Idle
              Is that a correct value on idle too? On a stock non modified Engine?
              • prj
                • Mar 2010
                • 6308
                Depends on the software it's running.
                Stock runs mid 12's on WOT, but there's hardly any boost.
                Most power on these engines is at about lambda 0.8, which is 11.8 in AFR terms.
                Of course on the top of the rev range, it makes sense to go richer for EGT control.
                After about lambda 0.78 or 11.4 AFR you start massively losing power.
                Idle should always be lambda 1, 14.7 for gasoline.
                • ineora
                  • Sep 2009
                  • 109
                  Right on startup, when the engine is cold, should it still be 14.7?
                  • EspenW
                    • Apr 2007
                    • 1534
                    • Country: Norway
                    14.7 when the sensor has warmed up and the ECU reads its signal. This takes a little while.
                    1994 80E Avant
                    1986 2L Golf 2 on Alcohol
                    • Laaf
                      • Oct 2010
                      • 275
                      As the ECU is running cold start enrichment then, no.
                      • HMS-S6
                        • Jan 2010
                        • 1164
                        Dmitri, Just refitted the stock ecu to my car and went for a run with the AFR rigged up. As it comes 'on' at around 3000 rpm (1bar) the AFR goes to 13-13.2 as it is hessitating, as it clears at around 4,500-5000 rpm at goes to high 11's-low 12's. Would you say that its lean running causing my issues?
                        • HMS-S6
                          • Jan 2010
                          • 1164
                          Afr
                          It seems the mapped ECU aggravates the problem even more. At idle the stock ecu gives a figure of 14.5 and the mapped one 16.2!!
                          • HMS-S6
                            • Jan 2010
                            • 1164
                            a slowmo log of the stock ecu in 3rd
                              Sounds lean to me... have you checked fuel pressure regulator and actual fuel flow capability from the pump ?
