The car isn't used much ... (it's been sorned since April) but over the past 3 years since it had a big overhaul it has developed a bad habit of cutting out while driving. Firstly it hesitates then the revs just dies away until it stals, the ignition switch was changed in March but it's done it twice since then most recently yesterday getting the car home from its storage hidy hole.
I'm going to get the imobiliser removed and see if that makes any difference, once it stals and the ignition turned off, the engine restarts on the first attempt and then it's fine for days or even months then without warning 👀
I'll vag com it when I get the chance as well, but any ideas other than an interfering imobiliser possibly being the cause, what if it's not the imobiliser what else could it be folks?👍🍻
Once it really fails, then it is easier.
