As im sure you are all aware i have just got my s2 running again before it was taken apart always had good strong oil pressure, started her up today ran up to temp to bleed all the cooling system and power steering ect, checked the radiator fan kicked in then taken her for a spin after going around the block a couple of times I came to a junction and the oil pressure light flashed on the dash, I looked at the oil pressure gauge and that read almost zero. When I put a few revs on the engine oil pressure went up to 2.5-3bar but then back down to almost zero after been revved, I parked it up for a hour started again now I'm getting 1 bar on tickover and 4bar when it's revved which seems more normal? Has anyone got any ideas what could cause this? I have used as always the VW Audi platinum 5-40.. Sorry to be a pest again
