Comparison of Bosch 044 and Deatschwerks DW300 Flow and Amp Curves.What am I missing?
The 39 mm Deatschwerks DW300 flow more than the 60 mm 044? (The Bosch curve doesn't mention voltage, could be at 12 V rather than Deatschwerks's 13.5 V).
I've added the annotations at 86 psig (5.93 Bar) based on 4 Bar pressure regulator and 28 psig boost on aggressive RS2 Stage 3 software
Thanks. Someone else just pointed these 4 pump comparo graphs out to me and suggested that they were likely done at the same voltage for all runs, standardizing the tests so a better comparo can be made.
Makes more sense, the 044 flows more than the Deatschwerks DW300 but not by much.
