Just bought an S2 - Temperature question
  • robinm
    • Feb 2005
    • 57
    Hi,
    I've read a few threads with people experiencing low coolant temperature when on the open road (60 deg). I have just bought an S2 and mine does the same. What I am unsure of is are all of our thermostats opening too quickly and should we be using a different one to keep the temp at 90 all the time? A few people seemed to have success when changing theirs. Is this true? Which thermostat works best?
    Another little quirk is that a red (brake i think) warning stop light comes on for a few seconds sometimes after starting. Do you think there is a pressure problem?
    Thanks for the help
    Robin
  • Skull
    • 3506
    • Country: Slovenia
    The most common reason for the low temp is that the rubber seals on the termostat are worn. Buy a new original (audi) termostat, it is cheap.
    Audi Quattro WR
    • SteveH
      • 4460
      to the forum
      Yup, a new stat will cure the problem. Do it sooner rather than later, cause you'll be throwing fuel away each time you drive it, when the coolant temp is low. A cheap part but not the nicest of jobs to do...
      The brake warning light is pretty common too. Try a change of the hydraulic fluid first, that may improve the situation. Only use the recommended fluid (G002000) Have a look on www.S2central.net for info on testing the bomb.
      Steve
      91 Modded 3B
      14 A6 Avant Black Edition
      • gavs20v
        • Sep 2004
        • 3057
        I had this on my urs4, changed the thermostat, flushed the system and mpg went up by between 8-10mpg.
        Nice one
        Gav
        S2 Cabriolet.........
        • coupegt
          • Jan 2005
          • 218
          • Country: Denmark
          i've had the brake warning come on also (just bought hte car) and after hyd. fluid change to the audi goo2000 the warning is completely gone, nice :-)
          My old fluid was very dark in colour and thicker than the new one. i wonder how old it was
          • robinm
            • Feb 2005
            • 57
            Thanks for that guys,
            I'll change the thermostat.
            I've noticed that the brakes go hard immediately after stopping the enigine (not even 1 pump, let alone 30). Reading the stuff on the bomb, I think that I have a problem there. Sounds expensive...
            Robin
            • rotoryboy
              • May 2004
              • 3281
              Keep your eye on this. Bomb on eb*y
              Mark
              Race Clio RS197
              S2 Coupe ABY (Green) - RIP
              S2 Coupe ABY (Blue) - Sold
              • Pete_RS2
                • 800
                Changing the 'stat may or may not change the temp reading. I know people who have change their's and it hasn't made any difference. It could just be the multifunction sensor being affected by airflow - see here.
                Now RS2'less
                '99 VW Passat VR5 Sport
                • s2avant95M
                  • 1217
                  • Home: England Current: United States
                  any pictures of where this sensor is located?
                  Tim
                  1995 S2 Avant, ruby red - ** SOLD TO ROSS **
                  Golf Rallye G60 ** SOLD **
                  Golf MK2 Oaky with R32 engine
                  Audi A6 Avant 1.9 TDi 130
                  Golf MK2 8v Race car
                  • Pete_RS2
                    • 800
                    AFAIK it's on the water rail by the inlet manifold. Could be wrong though. Anybody made a shield for the multi-function temp sensor & got any pic's ?
                    Now RS2'less
                    • AAH!
                      • 497
                      • Home: United Kingdom Current: Bhutan
                      The MFTS is marked "B"
                      From this thread (not so relevant to the original question)
                      Angus
                      formally RS2 +
