Massive oil leak due to the oil pressure switch
    #31
    Originally posted by CoupeWannabeS2
    Thanks.
    Quick question, do you need different types of clamps for silicone hoses, or are standard jubilee clips up to the job?
    I would have thought that standard oem jubilee clips are fine.
    • CoupeWannabeS2
      • 403
      Cheers.
      • K Simmonds
        • Dec 2007
        • 7627
        The stock jubilee clips are very good quality, as long as they haven't been over tightened they should last forever.
        I didn't bother refit the bit of ducting that goes on the side of the rad and makes access a pig, didn't notice any difference in how hot the engine runs or how often the fan kicks in. Only now I can change/check any of the components on that side of the engine in minutes, apart from the knock sensors, their a fiddle to get at whatever..
        I'd buy an OE switch and keep the Meyle one as an emergency spare.
        1990 B3 2.0 80 quattro.
        1992 C4 2.8 Avant quattro
        1994 MTM RS2.
        1998 B5 TDI quattro Sport.
        2000 B5 TQS.
        • CoupeWannabeS2
          • 403
          Cheers for the comments.
          I will leave the cowling off, so I can get better access. Also will save a tiny bit of weight aswell.
          • K Simmonds
            • Dec 2007
            • 7627
            No worries mate.
            Defo change those couple of hoses while your in there, also have a look what sort of state the knock sensors are in as you need the rad and fan out the way to deal with them. If their falling to bit's now would be the time to change them.
            1994 MTM RS2.
            2000 B5 TQS.
