Head welder???
  • zafra
    • Jun 2013
    • 320
    • Country: Spain
    Head welder???
    Hi, my cylinder head have a defect in the water pipes , I think the previous owner put normal water.
    You think that is necessary to weld the area?
    I will upgrade it , so I 'm checking it all .
    It is normal? They hold well?
    How much can it cost?
    Greetings .
    Step 1: setup. <==
    Step 2: potentiation.
    Step 3: enjoy.
    I don't think its necessary, it should seal fine. Remember coolant pressure is only around 1.2bar maximum
    • zafra
      • Jun 2013
      • 320
      • Country: Spain
      I search on ebay and all heads have this defect maybe i try put in, but i prefer listen testimonials.
      Thanks error 404
      Step 1: setup. <==
      Step 3: enjoy.
      • K Simmonds
        • Dec 2007
        • 7627
        A skim and that should be fine, I've seen much worse go back together and be OK.
        1990 B3 2.0 80 quattro.
        1992 C4 2.8 Avant quattro
        1994 MTM RS2.
        1998 B5 TDI quattro Sport.
        2000 B5 TQS.
