Hi all
Just changed the hall sensor on my RS2, now it takes a few turns of the engine to start, if I try to start without pressing accelerator, it takes ages to fire up, if I turn the ignition on and off a couple of times (I can hear the fuel pump running then stops) pump the accelerator a few times, turn it over and then the engine fires up, once running if stopped and started, it runs no problem, I think it's a fuel problem, as if the fuel is not getting to the injectors on first try, but I would like your thoughts and possible fix. By the way , no error faults found after clearing the G40 fault.
Dave S
Dave S
