Fpr can a newer unit be fitted ?
  • andyg plym
    • Nov 2006
    • 4646
    As the title says, can a newer a4 4 bar fpr be fitted, they look the same
    Cheers all !
    3B 7A AAN ABY ADU Fuel Pressure Regulator Info
    Originally posted by andyg plym
    As the title says, can a newer a4 4 bar fpr be fitted, they look the same. Cheers all !
    They might mount up but they might not flow the same.
    FPR info: http://forums.quattroworld.com/s4s6/msgs/21108.phtml
    • andyg plym
      • Nov 2006
      • 4646
      Ok they are pretty cheap it might be worth a punt.
      It's not very often you hear of them failing though
      • andyg plym
        • Nov 2006
        • 4646
        Anyone had one fail before ? Did it throw any codes ? Symptoms ?
          They are really common across most post 96 Audis. Mine was throwing mixture adaptation codes 00561 IIRC. Was stalling coming up to junctions etc, as well as dog rough idle, sooty tail pipe. Wasn't running boost at the time as was running engine in
          • andyg plym
            • Nov 2006
            • 4646
            Cheers Alex , I read somewhere that sometimes they don't throw any codes up
              I imagine if they go wrong enough to run badly there would be a code, otherwise the ECU will be able to adapt to compensate and carry on as normal
                They aren't electrical devices connected to the ECU so there is no direct code. However, as mentioned, there could be indirect codes as a result of running too lean or too rich because the fuel pressure regulator (FPR) *OR* the vacuum line to the FPR has sprung a leak.
                • andyg plym
                  • Nov 2006
                  • 4646
                  Interesting guys, Alex did yours behave badly all the time or just when cold for example ?
                  I replaced my hard line with silicone hose, it's all new.
                    Interesting guys, Alex did yours behave badly all the time or just when cold for example ? I replaced my hard line with silicone hose, it's all new.
                    How stiff is the silicone hose? It might be being sucked flat under vacuum and/or expanding under boost, killing ECU response speed. There was a good reason why the factory chose to use rigid tubing.
                      All the time
                      • andyg plym
                        • Nov 2006
                        • 4646
                        Hmm there has been a silicone hose on there for a long time, thick 8mm too.
                        I did even try flattening it by punching but made no difference to idle
                        • mike74
                          • Apr 2014
                          • 615
                          Nice, the "Chuck Norris" school of car maintenance!
                          • andyg plym
                            • Nov 2006
                            • 4646
                            Chuck who ?!
                            Is he local ? Sorry I'm not old enough to remember the olden days lol
                            • andy10v
                              • 5996
                              Sold ABY-stock
