Updated the N75, G71, N80, FPR and BPV info posts with this 3B/ABY/ADU info diagram
    N75 WGFV
    G71 Manifold Absolute Pressure sensor info
    N80 Evaporative Emissions Control Valve info
    Fuel Pressure Regulator info
    By-pass valve info
  • hermanio
    • Jan 2009
    • 800
    The links are not working
    5 Cylinder Freak
      Sorry. Fixed now.
      I did that post first in Kawf and then cut and pasted it into WORD and made the required FIND and REPLACE searches to change the formats and WORD put in different (slanted) double quotes instead of the required vertical ones, i.e. " .
      My bad for not checking the links.
