msd blaster ss coils?
  • bigcooler
    • Jan 2009
    • 229
    Has anyone used msd blaster coil packs if so is there a wiring diagram for them?
    It would help if you posted a link to the coil packs you are thinking of. Do that and I think I can get you the wiring diagram that you would need.
    • bigcooler
      • Jan 2009
      • 229
      Ebay.co.uk
      Item number: 121153636021
      Sorry i dont have a computer at hand and im thick
        Why not use LS2 coils? They are very powerful and 1/4 the price.
        • bigcooler
          • Jan 2009
          • 229
          I already have these ones and wanted to use them
            Cool
            • bigcooler
              • Jan 2009
              • 229
              The only issue is that I don't know how to wire them up
              • bigcooler
                • Jan 2009
                • 229
                Im currently running the 1.8t coil packs but want to upgrade to these
                  Ebay.co.uk Item number: 121153636021
                  As far as I can tell that MSD 8207 is for a single coil system. Even if it isn't, it doesn't have an internal Power Output Stage (POS), So it still needs something like the AAN ABY and ADU's N122 and N127 "351A" POSs.
                  In contrast the LS2 coils have built-in POS which eliminates the OE N122 and N127.
                  That said, I did find these:
                  https://www.mpsracing.com/instructio...ringManual.pdf (Huge 12Mb pdf)
                  Parts: - VW Ignition Control Module - MSD Blaster SS (PN 8207) - Four Electric Ring terminals – 2 are supplied with MSD blaster - Rubber Hose for isolation/spacer - Three 10-24 x 2-1/2 screw and bolt (coil to ICM mounts) - Two 1/4-20 x 1/2 screw and bolt (electrical contacts) - 16 gauge wire -...
                  Personally, I think you should sell them on and go LS2.
                  • bigcooler
                    • Jan 2009
                    • 229
                    • bigcooler
                      • Jan 2009
                      • 229
                      Anyone got a link to these ls2 coil packs?
                        Search for Delphi D514a.
                          CLICK
