Hello!
I have a AAN block/head with ADU cam pulley and 7A cams. I see that the ADU timing is supposed to have the cam pulley one tooth off, but does this still apply with 7A cams? I've tried searching the forums but I haven't found an answer for this combination.
I also have an intermittent problem with starting the engine. Sometimes it takes a while to fire, and when it does the revs build slowly until correct idle rpms. Other times it fires right up like normal. Bad contact on cam or flywheel sensor maybe?
