Searching for unicorns: 049133245 Banjo bolt with threaded head.
    Originally posted by UrS4boy
    Finally found the DEFI fuel pressure gauge pressure transducer/sender. It's NOT M10 x 1, it's 1/8" NPT (tapered pipe thread). So now I need to seek a new unicorn. M12 x 1.5 male and 1/8" NPT female threads.
    Someone found this for me. Unicorn no more.
    "Details about 1/8-27 NPT Tapped Banjo Bolt for VP44 Bosch Cummins Injection Pump
    GlowShift’s Banjo Bolt Adapter is specifically designed for the 1998.5-2010 Dodge Ram with a 24 valve Cummins motor. This adapter will replace your stock banjo bolt allowing you to easily install your snubber valve and fuel pressure sending unit directly to the fuel filter housing. The thread size for this banjo bolt is M12 x 1.5."
    eBay: http://www.ebay.com/itm/1-8-27-NPT-T...f97247&vxp=mtr
