Cars not running right , odd fault codes
  • RoadKill
    • Dec 2004
    • 567
    cars run spot of for all most 2 years after rebuild but is now not so good
    car has full RS2 parts and RS2 ECU , its not ticking over well at all (not the maff i have 3 still the same) if you hold the revs at say 3k its like its hit the rev limiter drops rpm the gos buck up then down , can get a vid to show this so pull codes with my hand held fault thing and got
    00002
    65282
    65535
    00255
    04351
    still boosts ok
    parts list
    RS2 injectors
    RS2 maff
    RS2 ECU high boost chips
    RS2 hybrid turbo
    RS2 inter-cooler
    044 fuel pump all new lines and filter
    3" turbo back d cat one box (sounds cool as ****!)
    Wagner manifold
    service tec @ East Kent Audi
    S2 ABY
    B8.5 A4
  • mike74
    • Apr 2014
    • 615
    MAF connector needing a clean/wiggle or boost leak would be my first guesses
