camshaft identification 034 102??
  • nicksonmsport
    • Mar 2014
    • 380
    Seems lots of cams can have 034 102 on them. I have aan cams here and they have 034 102g on them.
    The markings seem to be generic casting codes and dont always point to a specific camshaft.
    Hoping it is an rs2 cam but only way to know for sure is to check the timing with a dial gauge.
    • nicksonmsport
      • Mar 2014
      • 380
      So if it has no letter after it does it mean its from rs2?
      I have aan with 034 102g and that is confirmed aa aan as lift is 8.3mm. Lift on this cam is 9.5mm approx.
        I know the 034 102G exhaust cam is from an AAN because I removed it in order to install an RS2 exhaust cam. Unfortunately, I didn't take note or photos of the exact markings on the RS2 cam. (Or so I thought...see below)
        HOWEVER
        Turns out that I did start a thread: http://www.s2forum.com/forum/showthr...&highlight=rs2
        In which I said: "What I have is 034 --- 022 F. I tried asking KATE, under ATP regarding 034 109 022 F for all models but NOTHING shows up. When I check 034 109 022 D I get the AAN and ABY cam. Nothing under "E" or "F". And the one I have is an "F"."
        Jas11n said: "In this case 034 109 022 F (RS2 exhaust cam) was dropped on the 30/09/1997 and replaced with the current number given by Steve above, of 034 109 022 G."
        • nicksonmsport
          • Mar 2014
          • 380
          cam I have has nothing like those numbers, only 034 102 stamped on the cam. I rang tps and both those part numbers are no longer available now.
          wish they would just stamp part numbers in full on timing sprockets or cam ends to make this simple!!
          • rxl
            • 1913
            I find it also confusing. But I have 2 sets rs2 cams and few friends posted pictures of the cams.. The letter is always missing. And don't know why but early models of rs2 don't have the b letter in part number of the cam sprocket. So its kind of funny.
