3b engine rebuild info required.
Sorry for the off topic but maybe this will help you?
I have an AAN engine completely overhauled, engine builder is Pas Bogdan, the engine has new pistons, redone head etc, it's 500 km since new, the previous owner's car burnt after only 500 km of use
He had an S4, the battery problem... That's user Marius555
The engine comes 100% complete + ECU LOOM CLUTCH 01E gearbox.
Maybe you want to save time and money...????Comment
Spot on thanks I thought they were the ones just double checking I've taken the flywheel already off mine before it went to the rebuilders and the head so it's just the block crank and pistons at the moment I had the head skimmed and pressure tested so that's good to go.. Hopefully get it picked up this week so I can make a start..
Thanks for the thought I'll bear it in mind, I'm going to give mine ago first with the money I've spent onit parts ect.. if it goes wroung I maybe in touch haha!Sorry for the off topic but maybe this will help you?
[/IMG]
