K24 7200 420
  • arranstone
    • May 2011
    • 447
    K24 7200 420
    Just seen these turbos on eBay de
    http://www.ebay.de/itm/Sport-Turbola...item43d657720e
    Can anyone translate the text?
    Is this a genuine RS2 K24 7200?
    Is the price on an exchange basis?
  • AndyP
    • 6049
    You're not buying a turbo, they are just going to upgrade the one you have
    This auction includes the processing and the overhaul of the turbocharger delivered !
    This is possible only under the condition if the delivered turbocharger is fine,
    that is, no oil , boost pressure problems , grind, whistle , etc ...
    Audi RS2 P1 S2 S4 S6 Quattro 2,2T 20V 200 85 89 B4 C4 44
    Year: 1989 - 1997
    Engine: ADU , 3B, ABY , AAN , RR
    Displacement: 2226 cc
    Output: up to 309 kW / 420 hp
    zu.2.1 7907 , 0588
    zu.2.2 300, 301 , 440, 441, 442 , 443, 479 , 503, 569, 574, 575 , 518, 533
    The OEM BorgWarner K24 / 7200 turbochargers were optimized with the following changes :
    milled Extended Tip compressor with the latest compressor geometry
    gap- optimized by CNC turned compressor housing
    finely balanced to 0.05 g
    own production
    Plug and Play installation
    TTH - 7200-420
    Plug and Play installation on all Audi S2 Type 89 B4, C4 S4 , S6 C4, 44 200 and 85 Urquattro 5 cylinder 20V models .
    With the corresponding engine components and the adaptation of the engine Softwares , increase performance up to 420hp is possible
    • Rikki Kitto
      • Feb 2010
      • 6276
      Great info
      • arranstone
        • May 2011
        • 447
        Great, thanks for the quick reply. How did you translate the text or are you fluent in German?
        I take it you have to send them a RS2 K24 7200 and not an S2 K24 7000!
        • imp998
          • Nov 2013
          • 207
          Urs6 avant nogaro
          s2 avant
          • AndyP
            • 6049
            Yes, I used Google translate!
            • Albert
              • 1500
              • Country: Poland
              I'm doing similar service for much less (550 euro if turbo is delivered / 650 euro if not) and power ~450HP.
              AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
              • Quattronaut
                • May 2013
                • 273
                And I think your english is better than the ebay seller“s german, Albert ;-)
