2.0 16v ACE won't start
  • bungle74
    • Nov 2011
    • 87
    Hi All
    The rotor arm on my 94 16v ACE engines coupe blew itself apart a couple of weeks ago as discovered by the very nice man from the AA (eventually). I've replaced this and the dizzy cap as this was damaged by the aforementioned rotor arm. However, whilst the engine is turning and fuel is getting to the spark plugs the car just won't start. I'm guessing that no spark is being delivered to the plugs hence no firing up.
    I took the leads of the dizzy cap and put them on the new one so that I put them back in the right places but wonder if the man from the AA moved them about when he was looking at it. I say this as he took the plugs out to check they were ok and then tried to start the car without the ignition leads back on the plugs. Could this be a potential issue? I've tried to find a diagram of which lead goes to which point on the dizzy cap but have had no success.
    If anyone has a diagram or can tell me which plug connects to which connector on the dizzy I would be more than grateful. I'm a the end of my tether with it and need to get it running for Monday morning.
    Lee
