OEM Coils - How to Bench Test ?
This is a sticky topic.
    One of my oem coils is faulty between 3k and 4k, as a set of 1.8T style coils cured it, but I was wondering is there a way to bench test which of the original oem coils is faulty, assuming no visual issues are obvious with the wiring ?
    Thanks.
    One missing and hestitation diagnostics re: Coil
    Not sure about "bench" but these might help:
    One missing and hestitation diagnostic:
      Apologies to initial readers of the thread, I forgot to say that in December / January 2015 I'd changed the spark plugs to NGK, replaced the fuel filter, swopped in a good MAF, tightened all of the boost hoses, but as mentioned in the first post above it turned out to be one of the original coils breaking down under load between 3k and 4k under wot.
      I've yet to examine / test them to see if it was a coil or the wiring.
      HTH someone else in the future.
      • UUUdirs2newcastle
        • Apr 2008
        • 655
        Hmmm, I feel this is going to be me
