AAN oversize pistons
  • V6quattro
    • Sep 2008
    • 949
    Maybe you are interested in this:
    I think i will take a 82.5mm set
    • MuK1989
      • Sep 2012
      • 106
      Hmm interesting, am i correct if i say the original wrist pin size is 20mm?
      What would the CR be with 81.5 mm pistons?
      • MuK1989
        • Sep 2012
        • 106
        Just found this in an old topic
        • _ShurikeN
          • Mar 2010
          • 733
          • Country: Russian Federation
          Originally posted by MuK1989
          I also found 1 picture with the pistons and on top of the pistons it says 81.48. In the info sheet it says cilinder bore 81.51mm. That should mean a clearance of 0.03mm. Is this correct?
          Yes, It's clearance for OEM pistons. Clearance for forged pistons like Woessner may be different.
          • V6quattro
            • Sep 2008
            • 949
            Yes 20mm is the original size. CR at 81.5 is around 8.5:1
            I'm now running JE pistons made from 2618 alloy. But the pistons make a lot off noise and all-ready have wear marks on the skirt.
            I will run the engine this year but next winter i will take the engine apart to see if the skirt damage is become worse. I then like to try the 4032 or Mahle 142 alloy pistons. I think thy are more suitable on the street.
              Yup, I went for the Wossner due to tighter clearances - you want this on a road car I think. IIRC Wossner clearance is 0.03
              • diesel des
                • 3896
                #22
                Yep I'm running something like 0.03 clearance on the wossner pistons and have zero piston slap and little to no oil use.
                Sent from my SM-G900F using Tapatalk
                • JariP
                  • 192
                  It says 0.07 clearance on my box of wossners.
                  • diesel des
                    • 3896
                    #24
                    Fairly sure I'm running tighter than their recommend value.
                    • MuK1989
                      • Sep 2012
                      • 106
                      What kind of setups are you running with the wossners? And how much hp?
                      • diesel des
                        • 3896
                        #26
                        • FCP-ENGINEERING
                          • Feb 2011
                          • 173
                          • Country: Lithuania
                          #27
                          Woessner works well 4years in my 4cylinder 600hp 2,0 opel engine with out problem, so 750-800 in 5 cylinder with out problem.
                          Audi S4 2.6 20V STROKER kkk26/27
                            You are right: I couldn't remember so I checked.
                            I am running their recommended clearance. No piston slap or oil burn
                            • MuK1989
                              • Sep 2012
                              • 106
                              Today I got a quote from my local garage for the oversize Mahle pistons, it was €200 ex VAT each. So maby Mahle is getting interesting after all
                                Still 2x the price of Wossner
