Can you change the width of a timing belt ?
  • bartolomeus
    • Jan 2009
    • 1475
    • Country: Romania
    Later Edit:
    I've ordered a belt from Quattro Corner. I've checked the PN from the belt and the parts program was telling me the belt should be 4 mm wider.
    I've ordered the same PN belt from my parts supplier and the belt that came was 4 mm wider.
    So I was wondering if it's OK to take 4 mm from the width of a timing belt.
    Is this possible without damaging the integrity of the belt?
  • AndyP
    • 6049
    I certainly wouldn't want to try it! Why have you got to do that anyway?
      Originally posted by bartolomeus
      I need to take 4 mm from the width of a timing belt.
      I'll say NO. If you need a narrower belt, find a narrower NEW belt.
      • bartolomeus
        • Jan 2009
        • 1475
        • Country: Romania
        The narrower belt is very expensive
          • 4754
          Tut Tut Bart.
          • Majorcina
            • Jun 2013
            • 1334
            • Country: Montenegro
            I wouldnt play with that.It can end catastrophic
              Belts are carved out of cheese or cut off a massive roll like how they make toilet paper. The kevlar, etc. belt base is woven specifically for the application width. If narrow the belt by cutting it, you are cutting the strands that give the belt its strength.
              SO, again, NO!!
              • bartolomeus
                • Jan 2009
                • 1475
                • Country: Romania
                Well I've ordered a belt from Quattro Corner and the belt it arrived has a PN thate belongs to a belt 4 mm wider.
                So I thought he cut the belt.
                But he just confirmed the factory did that.
                I am relieved now
                • V6quattro
                  • Sep 2008
                  • 949
                  I found this one on a Peugeot last week. No problems at all
                  • denniselbows
                    • 740
                    Just out of curiosity why do you need a narrower belt ? Are you planning on running the engine with this belt or is it a ade for keeping things timed up when you are changing the belt or carrieing out work.
                    never set your expectations to high that way you are never disapointed
                    • bartolomeus
                      • Jan 2009
                      • 1475
                      • Country: Romania
                      I've just wrote above why I was wondering if it's OK, I have to edit my first post, I didn't write in English exactly what I meant...
                        Based on your revised initial post and the photo that you have now included, I think I need to re-think my comment that they don't make timing belts like toilet paper, i.e. multiple units on one long roll that are subsequently sheared into separate units. Based on the photo, I think that they might use that technique after all.
                        But they are *professionals*
                        • Tonybolony
                          • Dec 2011
                          • 636
                          Was that still running????
                          He needs to go and buy a lottery ticket right now
                          • bartolomeus
                            • Jan 2009
                            • 1475
                            • Country: Romania
                            Does anybody know for what car is the belt I bought?
