Do you want an inexpensive increase in I5 20Vt power and refinement ?
    • 4754
    Originally posted by prj
    Does not matter stock or not, I have the stock valve working with pressures of over 2.5 bar and I have not had any issues.
    Their usable life is about 8-10 years. Around that time they start to fail...
    I find it funny how people replace them with aftermarket stuff, because usually the aftermarket stuff hasn't even been around that long, and it's not proven it's better at all.
    So just get a new N75 in and forget the issue.
    "Their usable life is about 8-10 years." Thanks for that and good to know they are more than adequate of 2.5 bar and over.
    • Michael S2
      • Dec 2011
      • 1378
      Interesting read.
      Been meaning to fit my new ABY valve for a few months. My car pulls well but everything I've read on the forum suggests these deteriorate over time. Anything for a bit more pull and keeping it OE.
      1995 Audi S2 Avant
      • ericd
        • Nov 2003
        • 1240
        seen recent info that 710N is being superseded by 710P, just i case ur looking for the original....
          Eric, do you happen to know what the difference is between the two - N & P ?
          More durable, or better performance, or both ?
          Just curious, now I've fitted a new 710N.
            By-pass valve info
            Some BPV info including 710N = the best at the time. Not sure what a 710P would be from. The 710N was from the 225 hp TT (IIRC). Bosch sold the tooling to KAYSER so there are no more Bosch 710Ns. Not sure about the 710P.
            BPV info:
              #21
              Realistically, and tbh, I am very happy with my new 710N, so won't be looking to change.
              Car pulls strong, within the realms of it's spec, and the laws of physics as Dimitri says.
              The improvements were not massive in terms of the overall bhp, but definitely noticeable when you drive it everyday, and are obsessed. I feel I have a good butt dyno.
              Obviously it was not running as well as now over the last couple of months, but I didn't fully appreciate that, apart from the obvious and annoying hesitation fault caused by the coil which couldn't keep up under decent throttle load.
              • teamplatto
                • 10
                Wow
                • ericd
                  • Nov 2003
                  • 1240
                  i believe its supposed to have subtle internal changes to make it more robust and its operating specs have been tweaked
                  • Giacomo
                    • Apr 2014
                    • 523
                    • Country: Italy
                    #24
                    and what about the metal Forge one?
                    • Giacomo
                      • Apr 2014
                      • 523
                      • Country: Italy
                      #25
                      Afternoon Dimitri, good to see you're still lurking.
                      Thanks for you comments, very much appreciate your 'always informative' input on here.
                      Additionally, I'm sure I'm not the only one who enjoys your succinct posts.
                      Kind regards.
                      • Henkjan
                        • 1705
                        Does not work right with stock ecu. Power WILL drop.
                        I think it is possibly due to the different port/restrictor sizes.
                        thanks
                        it's been on my car for some time now, it was an improvement over the old one though.. so better to buy a new one then from the stealer
