Type 85 KV Oil pump/block seal
  • Monkeymagic
    • Mar 2012
    • 3419
    I have just completed a ton of work on a friends type 85. One of the jobs was oil leaking from what appeared to be the leading edge of the sump gasket.
    However after initial jubilation I was gutted to see it started leaking again. It is not coming from the crank seal and on closer inspection i suspect its coming from the gasket between the block and the oil pump about 1 inch above the sump gasket.
    The plan is to attack the cambelt and while thats apart do the paper gasket while im at it.
    I know its a sump off then obviously timing belt etc out of the way. Once they are is it a simple unbolt of oil pump and pull it forward? i assume its driven in the same way as other 5 cylinder lumps.??
    Anyone got any pointers, advice from people who have had the pitfalls is appreciated so I can plan ahead. Many thanks in adviance Steven.
  • quattro-nick
    • Sep 2012
    • 1746
    • Country: Belgium
    kv engine is the same as all other 5cil / 20v engine
    just remove cambelt and timing gear on crankshaft
    keep in mind if you mount the oil pump back that the drive teeth on the crankshaft is properly set for the oil pump
    TWINCHARGED power,zero lag
    AEM W/M injection
    • Monkeymagic
      • Mar 2012
      • 3419
      Brilliant thank you
